Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will lead you through the necessary steps required to replace the headphone jack in your phone.
Wat je nodig hebt
Turn hair dryer to medium heat.
Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
Circulate the dryer for a full minute to soften the adhesive binding the phone together.
Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
Remove the one 3 mm screw with the Phillips #000 screwdriver. The screw is located at the top right corner of the motherboard. The motherboard is the green/silver circuit board at the top of the phone.
Using with the plastic opening tool, pry up firmly from the bottom and top of the plastic housing. The housing is black and located at the top right corner of the phone.
Release the charging cover, located on the right side of the phone at the top. This should cause the housing piece to pop out effortlessly.
Release the copper tape located at the top middle of the phone with a plastic opening tool. This will take some force since the adhesive is rather strong.
With the plastic opening tool, release the pop connector, by lifting up to release it. The pop connector should still be attached to the copper tape.
Pull up gently on the copper tape and pop connector to remove the back camera. It should pop out easily.
With the plastic opening tool, gently pry the red tape away from motherboard. This pop connector is located at the top right corner of the phone.
Using your fingers, gently pull up on the pop connector to remove the front camera. The front camera piece should lift out effortlessly.
The SIM card of the Xperia Z is located in the unlabeled slot above the power button.
Gently open the cover by pushing it to the left.
Remove the two 3mm Phillips #000 screws located at the middle left and lower right of motherboard.
Place the plastic opening tool under the bottom side of the orange pop connector, and lift up towards the center of the headphone jack. The pop connector is located at the top left of the phone.
Carefully lift the tool upwards to release the headphone jack. You may grab the sensor cable to lift the part out of its position.
13 andere personen hebben deze handleiding voltooid.
2 opmerkingen
How many pins are on the ribbon cable that conects the screen to the motherboard?
Email me at xenoffline@gmail.com
Excellent guide Mollie. Superb and very detailed, including the tools and warnings needed. Will this guide help with my Sony Xperia Z5 Premium? It has a defective earphones jack that needs to be replaced. Thanks for your reply.
