Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unscrew 4x screws and disconnect 3x flex cables in case to free the mother board.
This are: main Camera, front Camera and antenna wire Flex cable.
Now we can remove the Motherboard.
The Headphone connector and the Ringer / Cover / Signal Antenna module.
Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go.
Warm the Touch screen before you start to disassemble it.
All's well, that ends well. :)
Did you do it successfully?
76 andere personen hebben deze handleiding voltooid.
54 opmerkingen
with a hairdryer for like 3 min on high
