Inleiding
This guide will walk you through the process of replacing or taking off the back cover panel of the Sony Xperia XZ Premium with a heat source and a thin wedge. The heat source is very hot and can cause burning to the skin, so be very careful.
Wat je nodig hebt
Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
Één andere persoon heeft deze handleiding voltooid.
