Ga door naar hoofdinhoud
Sony Xperia XA2 Ultra Motherboard Replacement
Wat je nodig hebt
  1. Sony Xperia XA2 Ultra Motherboard Replacement, Rear Cover: stap 1, afbeelding 1 van 2 Sony Xperia XA2 Ultra Motherboard Replacement, Rear Cover: stap 1, afbeelding 2 van 2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Motherboard Replacement: stap 3, afbeelding 1 van 2 Sony Xperia XA2 Ultra Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Motherboard Replacement: stap 4, afbeelding 1 van 2 Sony Xperia XA2 Ultra Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Motherboard Replacement: stap 5, afbeelding 1 van 2 Sony Xperia XA2 Ultra Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra Motherboard Replacement, Motherboard Bracket: stap 7, afbeelding 1 van 2 Sony Xperia XA2 Ultra Motherboard Replacement, Motherboard Bracket: stap 7, afbeelding 2 van 2
    • Remove the six 3 mm Phillips #000 screws.
  8. Sony Xperia XA2 Ultra Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the motherboard bracket with an iFixit opening tool.
  9. Sony Xperia XA2 Ultra Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Using the Jimmy, remove the two antenna flex cables.
  10. Sony Xperia XA2 Ultra Motherboard Replacement: stap 10, afbeelding 1 van 2 Sony Xperia XA2 Ultra Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Using the iFixit opening tool, pry and remove the motherboard.
Conclusie
Kristen Gismondi
82.698 Reputatie
202 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.430 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 162
