Ga door naar hoofdinhoud
Sony Xperia XA1 Ultra Headphone Jack Replacement
Wat je nodig hebt
  1. Sony Xperia XA1 Ultra Headphone Jack Replacement, Back Assembly: stap 1, afbeelding 1 van 2 Sony Xperia XA1 Ultra Headphone Jack Replacement, Back Assembly: stap 1, afbeelding 2 van 2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Headphone Jack Replacement, Antenna Module: stap 7, afbeelding 1 van 2 Sony Xperia XA1 Ultra Headphone Jack Replacement, Antenna Module: stap 7, afbeelding 2 van 2
    • Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
  8. Sony Xperia XA1 Ultra Headphone Jack Replacement: stap 8, afbeelding 1 van 2 Sony Xperia XA1 Ultra Headphone Jack Replacement: stap 8, afbeelding 2 van 2
    • Insert your iFixit Opening Tool underneath the antenna module.
    • Lift up gently with the iFixit Opening Tool to remove the antenna module.
    • The antenna module may be difficult to remove.
  9. Sony Xperia XA1 Ultra Headphone Jack Replacement, Front Camera: stap 9, afbeelding 1 van 2 Sony Xperia XA1 Ultra Headphone Jack Replacement, Front Camera: stap 9, afbeelding 2 van 2
    • Insert your iFixit Opening Tool underneath the front camera and gently lift up.
    • Remove the front camera by lifting the front camera up with your hands.
  10. Sony Xperia XA1 Ultra Headphone Jack Replacement, Headphone Jack: stap 10, afbeelding 1 van 2 Sony Xperia XA1 Ultra Headphone Jack Replacement, Headphone Jack: stap 10, afbeelding 2 van 2
    • Remove the 4mm T5 screw connecting the headphone jack to the panel.
  11. Sony Xperia XA1 Ultra Headphone Jack Replacement: stap 11, afbeelding 1 van 2 Sony Xperia XA1 Ultra Headphone Jack Replacement: stap 11, afbeelding 2 van 2
    • Use your iFixit Opening Tool to lift and disconnect the headphone jack connector piece.
    • The small black piece connected to the headphone jack that is holding the single screw in place has broken off in the device shown.
Conclusie
Jacob Jung
1.429 Reputatie
9 handleidingen geschreven
Cal Poly, Team S16-G3, Livingston Spring 2018 Lid van Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 660
