Inleiding
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
Wat je nodig hebt
Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
