Inleiding
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device. The headphone jack is held in by plastic retaining clips and may pop off when removed.
Wat je nodig hebt
Pry up the copper connector next to the battery with the plastic opening tool.
With the spudger, pry the headphone jack located in the top right corner of the phone.
Één andere persoon heeft deze handleiding voltooid.
