Inleiding
The fused display and globs of adhesive get the Sony Xperia X a repairability score of 6 out of 10.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
There are no exterior screws. The back panel is secured to the phone with medium strength adhesive.
Applying heat to the back panel softens up the adhesive, allowing an iSclack or other suction cup to separate the panel from the phone.
An opening tool can pry the plastic case the rest of the way off.
The rear panel contains no additional parts or cables.
Battery disconnection is straightforward, but to remove the battery you also have to disconnect the NFC antenna cable. The ID tag is not adhered and doesn't obstruct removal.
The battery assembly is adhered, but has a pull tab, making battery removal fairly easy.
The NFC antenna must be peeled off of the battery in order to replace either component.
The adhesive securing the antenna is quite strong, and since tools should not be pressed into the battery, it must be ripped off with brute force.
SIM card tray was easily removed with a fingernail.
The motherboard is secured by light adhesive and was easy to pry up.
The display and button cables are connected to the underside of the motherboard. However, the cables are long enough that you can tilt the board and disconnect the ZIF connectors without much chance of damage.
With the motherboard out of the way, we could remove the loudspeaker, headphone jack, USB-C port, button cable, interior and exterior button covers, and fingerprint sensor.
Modular components, especially high-wear ones like headphone jack and charging port are excellent for repair.
The Sony Xperia X Compact earns a 6 out of 10 on our repairability scale (10 is the easiest to repair):
Modular design allows for replacement of many individual components.
Battery is fairly easy to access and remove, but requires removal of the delicate NFC antenna to replace.
Adhesive used throughout will need to be replaced during reassembly, and may never be as waterproof again.
The fused display assembly is strongly adhered to the midframe and requires disassembling the entire phone to replace.
Manufacturer does not provide user-accessible repair documentation.
14 andere personen hebben deze handleiding voltooid.
5 Opmerkingen
Greath job!!
thank you sir
Hello, Thank you very much for this guide. My job was not as involved as changing the display. All I needed to do was to replace was the battery. I specifically ordered a battery LIS1634 that is for X Compact (and paid more than fair price for it I think) only to find out later that it is the same as LIS1594 - which is for Sony Z5 Compact (which I received instead of the one that I originally ordered). Also, I was able to save NFC antenna by removing/ cutting the plastic sheet from the original battery (cut around the battery, not into the battery as you are increasing the danger of short circuit/ possibly injury or fire) and then trimming it around the antenna. I only did this because I fixed the phone for my personal use. If you are doing it professionally, please do a proper job guys! I would include photos, but I can`t attach any here. After replacing the seal at the back of the phone, it is good as new. Many thanks again.
Hi how are things.
I am trying to repair a Sony Xperia X Compact, but I don't really know what and where the fault is. You may be able to help me with some voltage measurements at the load center and on the battery power side.
Thanks.
I'm having problems with some sensors (I think).
Can anyone tell me the location of the sensors? Problems are with the operation of the proximity sensor (not) and the gyro sensor (not).
Where is the electronics/connector of the proximity sensor located?
The problematic sensors are in separate phones. I am a DIY repairer for my own devices.
Thanks.
