Ga door naar hoofdinhoud
Sony Xperia U Battery Replacement
Wat je nodig hebt
  1. Sony Xperia U Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Battery Replacement: stap 2, afbeelding 1 van 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
Conclusie
Faisal
204 Reputatie
1 Handleiding geschreven
USF Tampa, Team 7-2, Leahy Fall 2014 Lid van USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,360
