Ga door naar hoofdinhoud
Sony Xperia TL Ear Speaker Replacement
Wat je nodig hebt
  1. Sony Xperia TL Ear Speaker Replacement, Remove Top Plastic Section: stap 1, afbeelding 1 van 3 Sony Xperia TL Ear Speaker Replacement, Remove Top Plastic Section: stap 1, afbeelding 2 van 3 Sony Xperia TL Ear Speaker Replacement, Remove Top Plastic Section: stap 1, afbeelding 3 van 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Ear Speaker Replacement, Remove Bottom Plastic Section: stap 2, afbeelding 1 van 2 Sony Xperia TL Ear Speaker Replacement, Remove Bottom Plastic Section: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Ear Speaker Replacement, Unscrewing the Back Off: stap 3, afbeelding 1 van 3 Sony Xperia TL Ear Speaker Replacement, Unscrewing the Back Off: stap 3, afbeelding 2 van 3 Sony Xperia TL Ear Speaker Replacement, Unscrewing the Back Off: stap 3, afbeelding 3 van 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Ear Speaker Replacement, Battery: stap 4, afbeelding 1 van 3 Sony Xperia TL Ear Speaker Replacement, Battery: stap 4, afbeelding 2 van 3 Sony Xperia TL Ear Speaker Replacement, Battery: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  5. Sony Xperia TL Ear Speaker Replacement, Sony Xperia TL Auxiliary Cord Replacement: stap 5, afbeelding 1 van 2 Sony Xperia TL Ear Speaker Replacement, Sony Xperia TL Auxiliary Cord Replacement: stap 5, afbeelding 2 van 2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Ear Speaker Replacement, Motherboard: stap 6, afbeelding 1 van 3 Sony Xperia TL Ear Speaker Replacement, Motherboard: stap 6, afbeelding 2 van 3 Sony Xperia TL Ear Speaker Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  7. Sony Xperia TL Ear Speaker Replacement, Ear Speaker: stap 7, afbeelding 1 van 1
    • Use the plastic opening tool to detach the ear piece speaker.
    • Avoid majorly bending the tiny metal hooks holding the ear piece in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Adam Giniger
1.303 Reputatie
8 handleidingen geschreven
USF Tampa, Team 4-4, Brown Fall 2014 Lid van USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 230
