Inleiding
I will teach you where it is and how to replace it.
Wat je nodig hebt
Use the plastic opening tool to pry the top plastic section off.
Use the plastic opening tool to pry the bottom plastic section off.
Remove the four 5mm screws.
Use the plastic opening tool to pry off the back.
Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
Één andere persoon heeft deze handleiding voltooid.
