Inleiding
This guide shows how to replace the top speaker of the phone. If you are having trouble hearing any audio out of the top speaker, then your top speaker must be replaced.
Wat je nodig hebt
Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
Use the tweezers to remove the top speaker carefully.
3 opmerkingen
Sony t2 ULRA PHONE How Display OR TOUCH DIZASTER replacement
I can see and touch is work properly but display is broken, please tell what is replace display or touch disaster?
