Ga door naar hoofdinhoud
Sony Xperia M4 Aqua Headphone Jack Replacement
Wat je nodig hebt
  1. Sony Xperia M4 Aqua Headphone Jack Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Headphone Jack Replacement: stap 3, afbeelding 1 van 2 Sony Xperia M4 Aqua Headphone Jack Replacement: stap 3, afbeelding 2 van 2
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
  5. Sony Xperia M4 Aqua Headphone Jack Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove copper plated tape and any other securing adhesive with a nylon spudger. Remove carefully, as it has the potential or tear if too much force is used.
  6. Sony Xperia M4 Aqua Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    • Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
  7. Sony Xperia M4 Aqua Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Pry the battery from the phone with the nylon spudger. There is a small amount of adhesive underneath the battery, so a bit of force is required. The battery is malleable, so it is possible to dent the battery if too much force is applied in one spot.
  8. Sony Xperia M4 Aqua Headphone Jack Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery once all of the adhesive is broken, and the connector is unplugged.
  9. Sony Xperia M4 Aqua Headphone Jack Replacement, Front Camera: stap 9, afbeelding 1 van 1
    • Release all connectors connecting to the motherboard.
    • Pry the motherboard up from the left side with the plastic pry tool and remove it.
    • Be very careful as the motherboard is tightly bound.
  10. Sony Xperia M4 Aqua Headphone Jack Replacement: stap 10, afbeelding 1 van 1
    • With your fingers, detach front camera connector from the back of motherboard.
    • Remove the front camera.
  11. Sony Xperia M4 Aqua Headphone Jack Replacement, Headphone Jack: stap 11, afbeelding 1 van 2 Sony Xperia M4 Aqua Headphone Jack Replacement, Headphone Jack: stap 11, afbeelding 2 van 2
    • With your fingers, or nylon spudger if necessary, remove headphone jack fastening cover, casing, and sticker.
  12. Sony Xperia M4 Aqua Headphone Jack Replacement: stap 12, afbeelding 1 van 1
    • Remove headphone jack with your fingers.
Conclusie
7 andere personen hebben deze handleiding voltooid.
John Whitt
672 Reputatie
2 handleidingen geschreven
USF Tampa, Team 4-5, Lacy Spring 2016 Lid van USF Tampa, Team 4-5, Lacy Spring 2016
USFT-LACY-S16S4G5
3 Leden
8 handleidingen geschreven
2 opmerkingen
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - Antwoord
"This is not Xperia Z3
This is a guide of the M4 Aqua" - Faruk
Just thought it could be told in english as well, cheerio!
Johan Andersson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 16
Altijd: 7,188
