Ga door naar hoofdinhoud
Sony Xperia L2 LTE Rear Camera Replacement
Wat je nodig hebt
  1. Sony Xperia L2 LTE Rear Camera  Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Xperia L2 LTE Rear Camera  Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Rear Camera  Replacement: stap 2, afbeelding 1 van 3 Sony Xperia L2 LTE Rear Camera  Replacement: stap 2, afbeelding 2 van 3 Sony Xperia L2 LTE Rear Camera  Replacement: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Rear Camera  Replacement: stap 3, afbeelding 1 van 1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Rear Camera  Replacement: stap 4, afbeelding 1 van 2 Sony Xperia L2 LTE Rear Camera  Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Rear Camera  Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Unclip circuit connectors from phone to motherboard.
  6. Sony Xperia L2 LTE Rear Camera  Replacement: stap 6, afbeelding 1 van 3 Sony Xperia L2 LTE Rear Camera  Replacement: stap 6, afbeelding 2 van 3 Sony Xperia L2 LTE Rear Camera  Replacement: stap 6, afbeelding 3 van 3
    • Use blue plastic opening tool to pry off the motherboard.
  7. Sony Xperia L2 LTE Rear Camera  Replacement, Rear Camera: stap 7, afbeelding 1 van 2 Sony Xperia L2 LTE Rear Camera  Replacement, Rear Camera: stap 7, afbeelding 2 van 2
    • Detach the rear camera from motherboard and remove it from the device.
Conclusie
Mikayla Wyatt
303 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 149
