Inleiding
You will be shown how to take apart your phone successfully up until you get to the piece you would like to change. Then you will be shown how to replace the desired part.
The battery should be removed before working on the phone internals.
Wat je nodig hebt
You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Once the silver plate has been detached from the phone, locate the speaker at the bottom of the silver plate.
Insert the tweezers' tip into the small hole located at the left side of the speaker. Once the tip is inside, just remove the speaker from left to right.
Place the new speakers in the same spot as the old one, and then push it with your finger until you hear a click.
Één andere persoon heeft deze handleiding voltooid.
