Ga door naar hoofdinhoud
Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement
Wat je nodig hebt
Video overzicht
  1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: stap 1, afbeelding 1 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: stap 1, afbeelding 2 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: stap 1, afbeelding 3 van 3
    • Switch-off the phone.
    • Remove the battery.
  2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 2, afbeelding 1 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 2, afbeelding 2 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 2, afbeelding 3 van 3
    • The small bottom bezel is held by 2x locking clips.
    • Preferably use plastic tools for disassembling.
  3. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 3, afbeelding 1 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 3, afbeelding 2 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 3, afbeelding 3 van 3
    • There are 4x silver screws and 3x black screws.
    • The rear cover is held by 5x locking clips.
    • Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
  4. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 4, afbeelding 1 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 4, afbeelding 2 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 4, afbeelding 3 van 3
    • Remove the back cover.
    • With a plastic tool disconnect one by one:
    • LCD Display flex cable
    • Touchscreen flex cable
    • Menu Buttons Board flex cable
    • Coaxial Wire Antenna cable
  5. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 5, afbeelding 1 van 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the main board.
  6. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 6, afbeelding 1 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 6, afbeelding 2 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the other side of the flex cable and remove the Home Buttons board.
    • Unstick the camera button.
  7. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 7, afbeelding 1 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 7, afbeelding 2 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 7, afbeelding 3 van 3
    • The touch screen is stuck to the frame with double side adhesive tape.
    • By using plastic tools gently start separating.
    • At the bottom is glued on firmly because the bonded surface is larger.
    • Use a hot air to make separating more easy and safety.
  8. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 8, afbeelding 1 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 8, afbeelding 2 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 8, afbeelding 3 van 3
    • With a plastic tool, carefully separate the LCD display from the touch screen.
    • Clear the touchscreen from the old adhesive tape.
  9. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 9, afbeelding 1 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 9, afbeelding 2 van 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 9, afbeelding 3 van 3
    • Install the new LCD into the frame and put adhesive tape.
    • Be careful not to cover the holes (for the speaker, menu buttons etc.). Install the Touchscreen.
  10. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: stap 10, afbeelding 1 van 1
Conclusie
Één andere persoon heeft deze handleiding voltooid.
ZFix
191.368 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.468 handleidingen geschreven
2 opmerkingen
Sir
Please help
Mera phone SONY C1504
Display connector kharab ho gya
Hai new mil sakta hai
Please help
Yogendra Singh - Antwoord
Jo PCB main hota hai
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 4,983
