Inleiding
Use this guide to replace the display on your Sony XPERIA Tablet Z.
This guide will take you through the process of removing the display and connection points to the motherboard.
This will require heating the screen to remove the adhesive be very careful as too much heat can damage the tablet its self.
Wat je nodig hebt
Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
8 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Do you need adhesive to attach new screen, & if so, what do you use?
Wooo its self explanatory.Good work
Where do I get the Screen if I'm in South Africa
