Ga door naar hoofdinhoud
Sony XPERIA Tablet Z Screen Replacement
Wat je nodig hebt
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Sony XPERIA Tablet Z Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Sony XPERIA Tablet Z Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: stap 2, afbeelding 1 van 3 Sony XPERIA Tablet Z Screen Replacement: stap 2, afbeelding 2 van 3 Sony XPERIA Tablet Z Screen Replacement: stap 2, afbeelding 3 van 3
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: stap 3, afbeelding 1 van 1
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: stap 4, afbeelding 1 van 1
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: stap 5, afbeelding 1 van 1
    • Clean adhesive from perimeter of frame to prepare for new screen.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Gustavo Correa
373 Reputatie
1 Handleiding geschreven
IUPUI, Team S5-G1, Harley Summer 2017 Lid van IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
4 Leden
3 handleidingen geschreven
5 opmerkingen
اريدشراءاريدشراءشاشه جديده
kore ares - Antwoord
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - Antwoord
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - Antwoord
Wooo its self explanatory.Good work
Duncan Mwaniki - Antwoord
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 56
Altijd: 6,924
