Ga door naar hoofdinhoud
Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement
Wat je nodig hebt
  1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: stap 1, afbeelding 1 van 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: stap 1, afbeelding 2 van 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: stap 1, afbeelding 3 van 3
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
  2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: stap 2, afbeelding 1 van 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: stap 2, afbeelding 2 van 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: stap 2, afbeelding 3 van 3
    • Remove tape connecting front camera to motherboard and then disconnect the camera from the port.
    • Lift the camera from the right and simply wiggle out of the slot.
  3. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: stap 3, afbeelding 1 van 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: stap 3, afbeelding 2 van 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the back camera from the port located in the upper right corner.
    • Lift up the camera cable using the tweezers.
    • Wiggle out camera from the slot.
Conclusie
Martin Luna
1.858 Reputatie
5 handleidingen geschreven
USF Tampa, Team 15-6, Remmell Fall 2014 Lid van USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 2,946
