Ga door naar hoofdinhoud
Sony XAV-AX100 Display Board Replacement
Wat je nodig hebt
  1. Sony XAV-AX100 Display Board Replacement, USB Cable: stap 1, afbeelding 1 van 3 Sony XAV-AX100 Display Board Replacement, USB Cable: stap 1, afbeelding 2 van 3 Sony XAV-AX100 Display Board Replacement, USB Cable: stap 1, afbeelding 3 van 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Display Board Replacement: stap 2, afbeelding 1 van 2 Sony XAV-AX100 Display Board Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Display Board Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Display Board Replacement: stap 4, afbeelding 1 van 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Display Board Replacement: stap 5, afbeelding 1 van 3 Sony XAV-AX100 Display Board Replacement: stap 5, afbeelding 2 van 3 Sony XAV-AX100 Display Board Replacement: stap 5, afbeelding 3 van 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Display Board Replacement, Motherboard: stap 6, afbeelding 1 van 2 Sony XAV-AX100 Display Board Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Display Board Replacement: stap 7, afbeelding 1 van 3 Sony XAV-AX100 Display Board Replacement: stap 7, afbeelding 2 van 3 Sony XAV-AX100 Display Board Replacement: stap 7, afbeelding 3 van 3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Display Board Replacement, Display: stap 8, afbeelding 1 van 1
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Display Board Replacement: stap 9, afbeelding 1 van 2 Sony XAV-AX100 Display Board Replacement: stap 9, afbeelding 2 van 2
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
  10. Sony XAV-AX100 Display Board Replacement, Display Board: stap 10, afbeelding 1 van 3 Sony XAV-AX100 Display Board Replacement, Display Board: stap 10, afbeelding 2 van 3 Sony XAV-AX100 Display Board Replacement, Display Board: stap 10, afbeelding 3 van 3
    • Remove the four 3.5mm Phillips #0 screws from the display board.
    • Remove the black tape using a precise tweezer.
    • Remove the 3.5mm Phillips #0 screw from underneath the tape.
  11. Sony XAV-AX100 Display Board Replacement: stap 11, afbeelding 1 van 1
    • Remove the two 2mm Phillips #0 screws from the back plate.
    • Remove the back plate.
  12. Sony XAV-AX100 Display Board Replacement: stap 12, afbeelding 1 van 1
    • Remove the single 2mm Phillips #0 screw from the motherboard.
  13. Sony XAV-AX100 Display Board Replacement: stap 13, afbeelding 1 van 1
    • Use a plastic opening tool to remove the display board from the radio.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Abdulaziz Redha
741 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G5, Cagle Spring 2018 Lid van USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Leden
Één opmerking
Where can I purchase the touch panel glass screen?
Steven olivarez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 36
Altijd: 1,928
