Inleiding
This tutorial will guide you in replacing the LCD display and cover.
Wat je nodig hebt
Remove the two black 6.4mm Phillips screws from the back of the device.
Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
Remove the two 2.8mm silver Phillips screws on the sides of the frame.
Insert a plastic prying tool between the bottom of the case and the motherboard.
Pry up the assembly and lift it away from the case.
To remove the LCD display cover, first melt the glue with the iOpener tool.
For more detailed instructions on how to use the iOpener, see iOpener Instructions
Carefully slide the iOpener wedge tool under the edge of the LCD display cover to separate it from the device.
Slide the wedge under all edges of the cover.
Once all of the glue has been broken, you can pull up on the cover to remove it.
The flat side of the spudger tool also works for this step
Één andere persoon heeft deze handleiding voltooid.
