Ga door naar hoofdinhoud
Sony Walkman NWZ-E438 Device Circuit Board Replacement
Wat je nodig hebt
  1. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Disassembling Sony Walkman NWZ-E438: stap 1, afbeelding 1 van 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Device Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: stap 3, afbeelding 1 van 3 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: stap 3, afbeelding 2 van 3 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: stap 3, afbeelding 3 van 3
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 Device Circuit Board Replacement: stap 4, afbeelding 1 van 2 Sony Walkman NWZ-E438 Device Circuit Board Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 Device Circuit Board Replacement: stap 5, afbeelding 1 van 1
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 Device Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Carefully remove the circuit board from the device.
Conclusie
For reassembling your device, follow the instructions in reverse.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 543
