Ga door naar hoofdinhoud
Sony WH-1000XM4 Battery Replacement
Wat je nodig hebt
  1. Sony WH-1000XM4 Battery Replacement, Place the headphones speakers-up: stap 1, afbeelding 1 van 1
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
    https://sony.encompass.com/item/11687300...
    You can get the battery from here as well!
    Will - Antwoord
  2. Sony WH-1000XM4 Battery Replacement, Create a gap: stap 2, afbeelding 1 van 2 Sony WH-1000XM4 Battery Replacement, Create a gap: stap 2, afbeelding 2 van 2
    • Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
  3. Sony WH-1000XM4 Battery Replacement, Unclip the ear cup: stap 3, afbeelding 1 van 3 Sony WH-1000XM4 Battery Replacement, Unclip the ear cup: stap 3, afbeelding 2 van 3 Sony WH-1000XM4 Battery Replacement, Unclip the ear cup: stap 3, afbeelding 3 van 3
    • Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • When the first clip disconnects, you'll hear an audible clicking sound.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  4. Sony WH-1000XM4 Battery Replacement: stap 4, afbeelding 1 van 3 Sony WH-1000XM4 Battery Replacement: stap 4, afbeelding 2 van 3 Sony WH-1000XM4 Battery Replacement: stap 4, afbeelding 3 van 3
    • Repeat the previous step around the perimeter of the ear cup to disconnect the remaining clips.
  5. Sony WH-1000XM4 Battery Replacement, Remove the ear pad: stap 5, afbeelding 1 van 2 Sony WH-1000XM4 Battery Replacement, Remove the ear pad: stap 5, afbeelding 2 van 2
    • Remove the right ear pad.
  6. Sony WH-1000XM4 Battery Replacement, Reassembly tip: stap 6, afbeelding 1 van 2 Sony WH-1000XM4 Battery Replacement, Reassembly tip: stap 6, afbeelding 2 van 2
    • When installing a replacement right ear pad:
    • Align the cushion over the speaker and press them firmly together to snap it into place.
    • Press around the entire edge of the cushion, making sure all the clips have engaged.
  7. Sony WH-1000XM4 Battery Replacement, Remove the foam liner: stap 7, afbeelding 1 van 1
    • Remove the foam liner from the right ear cup's speaker.
  8. Sony WH-1000XM4 Battery Replacement, Remove the ear cup cover screws: stap 8, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the four 8.4 mm screws securing the right ear cup cover.
    Hi there, on my headphones the screws on the bottom 2 seem to be really screwed on hard and I struggle to remove it, any advice?
    John Cespon - Antwoord
  9. Sony WH-1000XM4 Battery Replacement, Flip out the cover: stap 9, afbeelding 1 van 2 Sony WH-1000XM4 Battery Replacement, Flip out the cover: stap 9, afbeelding 2 van 2
    • Flip the headphones over, ear cups facing down.
    • Use your fingers to lift up and flip over the right ear cup cover.
    • Don't try to completely remove the cover just yet—it's still attached with the touch cable.
  10. Sony WH-1000XM4 Battery Replacement, Remove the right ear cup cover: stap 10, afbeelding 1 van 2 Sony WH-1000XM4 Battery Replacement, Remove the right ear cup cover: stap 10, afbeelding 2 van 2
    • Grip the touch ribbon cable and pull it straight out of its connector on the main board to remove it.
    • Remove the ear cup cover.
  11. Sony WH-1000XM4 Battery Replacement, Disconnect the battery: stap 11, afbeelding 1 van 2 Sony WH-1000XM4 Battery Replacement, Disconnect the battery: stap 11, afbeelding 2 van 2
    • Use a pair of tweezers to grip the edges of the battery connector, and pull up to disconnect it from the main board.
    • Always pull cables by their connectors and not the wires themselves.
    While pulling, the connector on the board ( the white thingy) came off. I did not even use force. Did I break it? I inspected but seemed there were no solders connecting to board, it appeared to have been glued by four tiny points. Which doesn’t make any sense, please help
    Abhiram Mishra - Antwoord
  12. Sony WH-1000XM4 Battery Replacement, Remove the thermal sensor: stap 12, afbeelding 1 van 3 Sony WH-1000XM4 Battery Replacement, Remove the thermal sensor: stap 12, afbeelding 2 van 3 Sony WH-1000XM4 Battery Replacement, Remove the thermal sensor: stap 12, afbeelding 3 van 3
    • If your replacement battery doesn't come with a thermal sensor preinstalled, you'll need to transfer your old one over from your old battery.
    • Whenever you use tweezers near the battery, be very careful not to puncture the battery.
    • Use a pair of tweezers to peel back the foam and adhesive covering the battery thermal sensor.
    • During reinstallation, make sure the diode on the end of the thermal sensor flex cable is facing up.
    SVP, est-ce que quelqu’un sait où trouver un remplacement pour l’adhésif qui recouvre le capteur thermique du casque ?
    josselin.abrivard - Antwoord
    Je recommanderais d'utiliser un petit morceau de ruban électrique. Bonne réparation !
    Carsten Frauenheim -
  13. Sony WH-1000XM4 Battery Replacement: stap 13, afbeelding 1 van 2 Sony WH-1000XM4 Battery Replacement: stap 13, afbeelding 2 van 2
    • Use a pair of tweezers to pull up on the thermal sensor ribbon cable to disconnect it from the main board.
    • Pull only on the darker pull-tab section of the cable, not the cable itself.
    • Remove the thermal sensor.
  14. Sony WH-1000XM4 Battery Replacement, Pry up the battery: stap 14, afbeelding 1 van 3 Sony WH-1000XM4 Battery Replacement, Pry up the battery: stap 14, afbeelding 2 van 3 Sony WH-1000XM4 Battery Replacement, Pry up the battery: stap 14, afbeelding 3 van 3
    • Slide the flat end of a spudger under the top-lefthand corner of the battery.
    • Push the spudger underneath the battery, prying up intermittently to work the battery away from its adhesive.
    • Remove the battery.
    • Don't reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a new battery:
    • Remove any remaining adhesive from the battery well.
    • If your replacement battery does not come with replacement adhesive, lay some double-sided tape or pre-cut adhesive strips in the headphone's battery well.
    • Peel away any tape liners to expose the adhesive.
    • Lay the battery on the adhesive and press firmly.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
18 andere personen hebben deze handleiding voltooid.
Carsten Frauenheim
91.982 Reputatie
337 handleidingen geschreven
iFixit Lid van iFixit
Community
141 Leden
17.643 handleidingen geschreven
7 opmerkingen
You can also get the battery from sony’s site!
Will - Antwoord
In reply to the previous comment, that is NOT “sony’s site”. Encompass is not Sony! They distribute parts for hundreds of different brands, not just Sony. I’m not saying there’s anything wrong with them but don’t mislead people into thinking they’re buying directly from Sony!
Haitham - Antwoord
Thanks for this guide. I was able to repair a loose cable on my XM3s with this disassembly information.
Since the design of the models are mostly the same it would be nice to have a similar disassembly guide on the XM3 website too.
X West - Antwoord
como puedo adquirir la batería con el sensor térmico preinstalado de los audífonos sony wh1000xm4 ????? avisarme a josephchr_est@hotmail.com
Dental Service - Antwoord
Bought one tool kit. Buying a few more, because all the guides on this site have saved me hours of frustration.
Thank you, IFixIt, please don't change!!!
Michal Rysanek - Antwoord
will a 3.7Wh battery work? the only replacement batteries I've found available in my area are the 3.7Wh ones for the XM3s
prisbertalejo - Antwoord
Followed the excellent instructions on this page and disconnected the battery on my XM4 headphone, left it unhooked for a while, then reconnected enough parts to put it on the charger, left it there for several hours, and now my battery, which wouldn't hold a charge at all, is reading 100 percent. Very pleased. Also bought the iFixit set of 3 tweezers which are very nice.
Steve Thornton - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 125
Afgelopen 7 dagen: 920
Afgelopen 30 dagen: 4,439
Altijd: 75,943
