Ga door naar hoofdinhoud
Sony WF-1000XM3 Battery Replacement
Wat je nodig hebt
    • Follow the video step by step as it shows the entire process of replacing the battery
Conclusie
Follow the video to replace the batteries of your ear buds
17 andere personen hebben deze handleiding voltooid.
Ludovic O.
631 Reputatie
1 Handleiding geschreven
17 opmerkingen
Thanks for the guide! Just replaced the batteries in mine - oddly, the original batteries were “Zenipower Z55”.
Glad I didn't have to throw them out and buy another set (lookin’ at you, Apple and Samsung!)
No idea how you were so smooth with opening the case, took me ten minutes going around in circles for each bud lol
Jason - Antwoord
could you provide the link to buy those batteries and also what is the battery life now after replacing?
Shivam Patel -
This worked like a charm ? One thing I noticed however: I don’t know if it’s a design chance with later revisions, but when I popped my cover open, the touchscreen and microphone assembly were firmly attached to the cover. Thus, the cover did not separate from the board, like shown in the video. Meaning that if I hadn’t been careful with the plastic picks, I could have accidentally sliced the ribbon cable connecting the touchscreen/mic assembly to the board! Keep that in mind and be careful! Even though these have a difficulty level of “easy”, they are DEFINITELY not meant to be opened and/or repaired!
Maximilian S. - Antwoord
Happened to me on one of the earbuds! I do believe that it came from wear and spread of the adhesive that usually attaches the touchscreen/mic-assembly to the inside of the bud instead of the top cover.
Maximilian Binder -
Thanks reallyhelpful video
but Just becarful when putting the metal thing on the battery because you can short circuit the battery (produce heat and may explode), I think it is safer to first put back the metal thing back in the case then put back the battery (cannot short circuit that way)
Patrick Delcroix - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 115
Afgelopen 7 dagen: 804
Afgelopen 30 dagen: 3,880
Altijd: 52,489
