Inleiding
This easy to follow replacement guide is helpful if your fan is making a funny noise or overheating.
Wat je nodig hebt
Place your device upside down with the bottom panel facing upwards.
Orient the device so the battery is away from you as shown
Place the laptop upside down with the bottom panel facing upwards.
Locate the screw that holds the small panel covering your laptop's Ram. This panel should be in the dead center of your laptop.
Unscrew the screw and remove the panel.
Één andere persoon heeft deze handleiding voltooid.
