Ga door naar hoofdinhoud
Sony Vaio VPCW21FX Fan Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. Sony Vaio VPCW21FX Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Sony Vaio VPCW21FX Fan Replacement: stap 2, afbeelding 1 van 2 Sony Vaio VPCW21FX Fan Replacement: stap 2, afbeelding 2 van 2
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Sony Vaio VPCW21FX Fan Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VPCW21FX Fan Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery from your laptop.
  4. Sony Vaio VPCW21FX Fan Replacement, Headphone Jack: stap 4, afbeelding 1 van 2 Sony Vaio VPCW21FX Fan Replacement, Headphone Jack: stap 4, afbeelding 2 van 2
    • Place the laptop upside down with the bottom panel facing upwards.
    • Locate the screw that holds the small panel covering your laptop's Ram. This panel should be in the dead center of your laptop.
    • Unscrew the screw and remove the panel.
  5. Sony Vaio VPCW21FX Fan Replacement: stap 5, afbeelding 1 van 1
    • Before you move away from where your RAM is located, be sure to unplug the wire labeled To MB. If you do not unplug this, the back panel you are trying to remove will not come off.
  6. Sony Vaio VPCW21FX Fan Replacement: stap 6, afbeelding 1 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 6, afbeelding 2 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 6, afbeelding 3 van 3
    • Next, locate the panel covering your laptop's hard drive. This panel should be located on the lower right hand side of your laptop.
    • Unscrew the cover on the hard drive.
    • Remove the hard drive cover.
  7. Sony Vaio VPCW21FX Fan Replacement: stap 7, afbeelding 1 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 7, afbeelding 2 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 7, afbeelding 3 van 3
    • Remove screws.
    • Remove screws and remove panel.
  8. Sony Vaio VPCW21FX Fan Replacement: stap 8, afbeelding 1 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 8, afbeelding 2 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 8, afbeelding 3 van 3
    • Remove the hard drive by gently pressing down on it and sliding it to the right.
    • Remember to have a clean work space to place the parts you take off your laptop. It'd be embarrassing to forget to reassemble a part or have a screw or two left over.
  9. Sony Vaio VPCW21FX Fan Replacement: stap 9, afbeelding 1 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 9, afbeelding 2 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 9, afbeelding 3 van 3
    • Remove the screws holding the rest of the outside panel down.
    • Gently lift the panel up to remove it once all the screws have been removed.
  10. Sony Vaio VPCW21FX Fan Replacement: stap 10, afbeelding 1 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 10, afbeelding 2 van 3 Sony Vaio VPCW21FX Fan Replacement: stap 10, afbeelding 3 van 3
    • Once the back panel has been removed, set the rest of your laptop to the side and place the panel you just removed in front of you.
    • Locate the headphone jack, which will be in the top right hand corner of the panel. The headphone jack board is a bright green, you can't miss it.
  11. Sony Vaio VPCW21FX Fan Replacement: stap 11, afbeelding 1 van 2 Sony Vaio VPCW21FX Fan Replacement: stap 11, afbeelding 2 van 2
    • Remove the screws holding the headphone jack board down.
  12. Sony Vaio VPCW21FX Fan Replacement: stap 12, afbeelding 1 van 2 Sony Vaio VPCW21FX Fan Replacement: stap 12, afbeelding 2 van 2
    • Gently pull the board to remove it.
  13. Sony Vaio VPCW21FX Fan Replacement, Fan: stap 13, afbeelding 1 van 2 Sony Vaio VPCW21FX Fan Replacement, Fan: stap 13, afbeelding 2 van 2
    • Locate the fan on the top right hand corner of your laptop.
  14. Sony Vaio VPCW21FX Fan Replacement: stap 14, afbeelding 1 van 2 Sony Vaio VPCW21FX Fan Replacement: stap 14, afbeelding 2 van 2
    • Remove screws.
    • Unplug the wires connecting the fan and the motherboard.
  15. Sony Vaio VPCW21FX Fan Replacement: stap 15, afbeelding 1 van 1
    • Gently pick up the fan to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Summer
250 Reputatie
2 handleidingen geschreven
Één opmerking
thank you, sir!!!
Robin Watson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,303
