Ga door naar hoofdinhoud
Sony Vaio VPCEL17FX Hard Drive Replacement
Wat je nodig hebt
  1. Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: stap 1, afbeelding 3 van 3
    • First, locate the hard drive slot on the under side of the laptop.
    • Unscrew the screws using your Phillips #00 screwdriver.
    • Set the two screws aside so you can screw them in later on when you're finished.
    • This should reveal a small metallic place holder that your hard drive belongs.
  2. Sony Vaio VPCEL17FX Hard Drive Replacement: stap 2, afbeelding 1 van 2 Sony Vaio VPCEL17FX Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the 4 hard drive bracket screws.
    • Once the screw is undone you can pull the place holder back to find the slot where the actual hard drive belongs.
    • Remember to set aside the screw so you can correctly install the hard drive.
Conclusie
The installation/replacement is a very easy task that can be done by anyone.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 619
