Ga door naar hoofdinhoud
Sony Vaio VPCEG26FX Back Panel Replacement
Wat je nodig hebt
  1. Sony Vaio VPCEG26FX Back Panel Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop so the bottom is facing up with the model number visible.
  2. Sony Vaio VPCEG26FX Back Panel Replacement: stap 2, afbeelding 1 van 2 Sony Vaio VPCEG26FX Back Panel Replacement: stap 2, afbeelding 2 van 2
    • Slide the lock switch down until you hear a click to unlock the battery.
  3. Sony Vaio VPCEG26FX Back Panel Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VPCEG26FX Back Panel Replacement: stap 3, afbeelding 2 van 2
    • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
  4. Sony Vaio VPCEG26FX Back Panel Replacement: stap 4, afbeelding 1 van 2 Sony Vaio VPCEG26FX Back Panel Replacement: stap 4, afbeelding 2 van 2
    • Remove the battery from the battery compartment.
  5. Sony Vaio VPCEG26FX Back Panel Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Loosen the two (7mm) screws that hold the hard drive panel in place with a JIS #0 screwdriver.
    • These screws cannot be removed.
  6. Sony Vaio VPCEG26FX Back Panel Replacement: stap 6, afbeelding 1 van 1
    • Remove the plastic and unscrew the screw on the hard drive using the JIS #0 screwdriver.
  7. Sony Vaio VPCEG26FX Back Panel Replacement: stap 7, afbeelding 1 van 1
    • Push the hard drive towards the optical reader to unlock it.
  8. Sony Vaio VPCEG26FX Back Panel Replacement: stap 8, afbeelding 1 van 1
    • Remove the hard drive from the device.
  9. Sony Vaio VPCEG26FX Back Panel Replacement, RAM: stap 9, afbeelding 1 van 1
    • After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
  10. Sony Vaio VPCEG26FX Back Panel Replacement: stap 10, afbeelding 1 van 1
    • Remove the single screw holding the panel in place using the JIS #0 screwdriver.
  11. Sony Vaio VPCEG26FX Back Panel Replacement: stap 11, afbeelding 1 van 3 Sony Vaio VPCEG26FX Back Panel Replacement: stap 11, afbeelding 2 van 3 Sony Vaio VPCEG26FX Back Panel Replacement: stap 11, afbeelding 3 van 3
    • Remove the green circuit board by dislodging the circuit it is attached to.
    • Unhook it and remove it from the device.
  12. Sony Vaio VPCEG26FX Back Panel Replacement, Back Panel: stap 12, afbeelding 1 van 1
    • Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
  13. Sony Vaio VPCEG26FX Back Panel Replacement: stap 13, afbeelding 1 van 2 Sony Vaio VPCEG26FX Back Panel Replacement: stap 13, afbeelding 2 van 2
    • Remove the back panel from the device.
Conclusie
Sara Alfaro
531 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S1-G4, Botvin Spring 2019 Lid van UMass Dartmouth, Team S1-G4, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 905
