Inleiding
This guide is used to replace the Sony Vaio VPCEB11FM Wi-Fi Card. This repair might be needed when the laptop no longer connects to the internet via Wi-Fi due to the faulty card. This repair would resolve the problem of not being able to connect to the internet via Wi-Fi. There are no special skills and there is nothing unusual about this repair.
Wat je nodig hebt
Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
Once the cover has been loosened, pry the cover with your finger for it to come off.
Remove ten 7mm screws with the Phillips #1 Screwdriver.
Remove two 8mm screws with the Phillips #1 Screwdriver.
Remove two 3mm screws with the Phillips #1 Screwdriver.
Één andere persoon heeft deze handleiding voltooid.
