Ga door naar hoofdinhoud
Sony Vaio VPCCW17FX Webcam Replacement
Wat je nodig hebt
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: stap 1, afbeelding 1 van 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: stap 2, afbeelding 1 van 1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VPCCW17FX Webcam Replacement: stap 3, afbeelding 2 van 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: stap 4, afbeelding 1 van 2 Sony Vaio VPCCW17FX Webcam Replacement: stap 4, afbeelding 2 van 2
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: stap 5, afbeelding 1 van 2 Sony Vaio VPCCW17FX Webcam Replacement: stap 5, afbeelding 2 van 2
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: stap 6, afbeelding 1 van 3 Sony Vaio VPCCW17FX Webcam Replacement: stap 6, afbeelding 2 van 3 Sony Vaio VPCCW17FX Webcam Replacement: stap 6, afbeelding 3 van 3
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
Conclusie
Tiffani Beck
219 Reputatie
2 handleidingen geschreven
Texas Tech, Team S8-G5, Bennett Spring 2017 Lid van Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 1,108
