Ga door naar hoofdinhoud
Sony Vaio VPCCW17FX Speakers Replacement
Wat je nodig hebt
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: stap 1, afbeelding 1 van 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: stap 2, afbeelding 1 van 1
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VPCCW17FX Speakers Replacement: stap 3, afbeelding 2 van 2
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: stap 4, afbeelding 1 van 2 Sony Vaio VPCCW17FX Speakers Replacement: stap 4, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: stap 5, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: stap 6, afbeelding 1 van 1
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: stap 7, afbeelding 1 van 2 Sony Vaio VPCCW17FX Speakers Replacement: stap 7, afbeelding 2 van 2
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: stap 8, afbeelding 1 van 2 Sony Vaio VPCCW17FX Speakers Replacement: stap 8, afbeelding 2 van 2
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: stap 9, afbeelding 1 van 3 Sony Vaio VPCCW17FX Speakers Replacement: stap 9, afbeelding 2 van 3 Sony Vaio VPCCW17FX Speakers Replacement: stap 9, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
Conclusie
Brianna Rukes
101 Reputatie
1 Handleiding geschreven
Texas Tech, Team S8-G5, Bennett Spring 2017 Lid van Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 486
