Ga door naar hoofdinhoud
Sony Vaio VPCCW17FX Hard Drive Replacement
Wat je nodig hebt
  1. Sony Vaio VPCCW17FX Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the two latches towards the center of the battery to release it.
  3. Sony Vaio VPCCW17FX Hard Drive Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VPCCW17FX Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Hard Drive Replacement: stap 4, afbeelding 1 van 2 Sony Vaio VPCCW17FX Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the two 7.7 mm screws from the hard drive cover and place it to the side.
  5. Sony Vaio VPCCW17FX Hard Drive Replacement: stap 5, afbeelding 1 van 3 Sony Vaio VPCCW17FX Hard Drive Replacement: stap 5, afbeelding 2 van 3 Sony Vaio VPCCW17FX Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
    • Use the tab to slide the hard drive away from the laptop.
    • Set the disconnected hard drive away from the laptop.
  6. Sony Vaio VPCCW17FX Hard Drive Replacement: stap 6, afbeelding 1 van 3 Sony Vaio VPCCW17FX Hard Drive Replacement: stap 6, afbeelding 2 van 3 Sony Vaio VPCCW17FX Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
    • Use the tab to pull up on the metal cover and remove it.
    • You are now free to replace the hard drive.
Conclusie
Tiffani Beck
219 Reputatie
2 handleidingen geschreven
Texas Tech, Team S8-G5, Bennett Spring 2017 Lid van Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 1,629
