Inleiding
If your computer is only displaying a black screen, or if it is struggling to run multiple programs, you may need to replace your RAM. This guide will walk you through how to remove your RAM cards -- the same process for either card -- requiring only a PH0 screwdriver.
Wat je nodig hebt
Use a #0PH screwdriver to unscrew the three 4.80mm screws.
Remove the panel.
Één andere persoon heeft deze handleiding voltooid.
