Ga door naar hoofdinhoud
Sony Vaio VPC-Y2190X Motherboard Replacement
Wat je nodig hebt
  1. Sony Vaio VPC-Y2190X Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 3, afbeelding 2 van 2
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X Motherboard Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
    • The screws are held into the panel by washers, they will not fall out once unscrewed.
  5. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the panel.
    • Use the #0PH screwdriver to remove the four 3.61mm screws.
  6. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 6, afbeelding 1 van 2 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Carefully lift the hard drive.
    • Remove the hard drive by pulling it to the left.
  7. Sony Vaio VPC-Y2190X Motherboard Replacement, Fan: stap 7, afbeelding 1 van 1
    • Remove all nine 5.63mm screws with the #0PH screwdriver.
    • Remove the four 8.62mm screws with the #0PH screwdriver.
  8. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 8, afbeelding 1 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 8, afbeelding 2 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Flip your Vaio so that the keyboard is facing up.
    • Use the iFixit Opening Tool to lift the keyboard from the frame, starting at the ESC key corner.
    • Gently slide the iFixit Opening Tool along the edge of the keyboard.
    • The keyboard is connected to the frame with a wire, do not fully lift the keyboard from the frame
  9. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 9, afbeelding 1 van 2 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 9, afbeelding 2 van 2
    • The cable is located under the keyboard, just above the touchpad.
    • Use the iFixit Opening Tool to flip the clip up in order to release the cable.
    • Detach the cable from the frame.
    • Remove the keyboard from the frame.
  10. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 10, afbeelding 1 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 10, afbeelding 2 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Use the iFixit Opening Tool to lift the edge of the clip from the cable.
    • Gently pull the cable away from the clip.
    • Repeat the first two steps on the second clip shown in the picture.
  11. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 11, afbeelding 1 van 2 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Use the iFixit Opening Tool to detach the cable from the motherboard.
    • Use the small needle nose pliers to pull the cable from the motherboard.
  12. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 12, afbeelding 1 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 12, afbeelding 2 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Use the iFixit Opening Tool to flip the clip up in order to release the first cable.
    • Use the small needle nose pliers to pull the second cable from where it is attached.
    • Use the small needle nose pliers to detach the third cable from motherboard.
  13. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 13, afbeelding 1 van 2 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Use the iFixit Opening Tool to lift the back of the Vaio from the frame.
    • Slide the iFixit Opening Tool around the edges of the frame.
  14. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 14, afbeelding 1 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 14, afbeelding 2 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Use the small needle nose pliers to pull the cable connector from the motherboard.
    • Push the flap to the side so you can access the screw beneath.
    • Use the #0PH screwdriver on the one 5.63mm screw.
  15. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Unscrew the 5.63mm screw tethering the motherboard to the laptop with a #0PH screwdriver.
    • Remove the piece from the motherboard.
  16. Sony Vaio VPC-Y2190X Motherboard Replacement: stap 16, afbeelding 1 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 16, afbeelding 2 van 3 Sony Vaio VPC-Y2190X Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Flip the motherboard upside down to access the other side.
    • Use a #0PH screwdriver to remove the three 3.61mm screws holding the fan to the motherboard.
    • Remove the fan from the motherboard.
  17. Sony Vaio VPC-Y2190X Motherboard Replacement, Motherboard: stap 17, afbeelding 1 van 2 Sony Vaio VPC-Y2190X Motherboard Replacement, Motherboard: stap 17, afbeelding 2 van 2
    • Remove the three 5.63mm screws using the 0PH screwdriver.
    • Remove the motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 541
