Inleiding
If your laptop is overheating you may need to replace the fan. This guide will guide you in replacing your laptop’s fan. The tools required in this process are: an iFixit opening tool, a PH0 screwdriver, and needle nose pliers.
Wat je nodig hebt
Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
The screws are held into the panel by washers, they will not fall out once unscrewed.
Remove all nine 5.63mm screws with the #0PH screwdriver.
Remove the four 8.62mm screws with the #0PH screwdriver.
