Ga door naar hoofdinhoud
Sony Vaio VGN-TXN25N Keyboard Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-TXN25N Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Take out the screw in the center of the computer.
  2. Sony Vaio VGN-TXN25N Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  3. Sony Vaio VGN-TXN25N Keyboard Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VGN-TXN25N Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  4. Sony Vaio VGN-TXN25N Keyboard Replacement: stap 4, afbeelding 1 van 2 Sony Vaio VGN-TXN25N Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  5. Sony Vaio VGN-TXN25N Keyboard Replacement: stap 5, afbeelding 1 van 3 Sony Vaio VGN-TXN25N Keyboard Replacement: stap 5, afbeelding 2 van 3 Sony Vaio VGN-TXN25N Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
Conclusie
Austen
32 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-3, Forte Spring 2012 Lid van Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 23
Altijd: 2,081
