Ga door naar hoofdinhoud
Sony Vaio VGN-TXN25N Display Screen Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: stap 1, afbeelding 1 van 2 Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: stap 1, afbeelding 2 van 2
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Sony Vaio VGN-TXN25N Display Screen Replacement: stap 2, afbeelding 1 van 3 Sony Vaio VGN-TXN25N Display Screen Replacement: stap 2, afbeelding 2 van 3 Sony Vaio VGN-TXN25N Display Screen Replacement: stap 2, afbeelding 3 van 3
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Sony Vaio VGN-TXN25N Display Screen Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VGN-TXN25N Display Screen Replacement: stap 3, afbeelding 2 van 2
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Sony Vaio VGN-TXN25N Display Screen Replacement: stap 4, afbeelding 1 van 3 Sony Vaio VGN-TXN25N Display Screen Replacement: stap 4, afbeelding 2 van 3 Sony Vaio VGN-TXN25N Display Screen Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Sony Vaio VGN-TXN25N Display Screen Replacement: stap 5, afbeelding 1 van 3 Sony Vaio VGN-TXN25N Display Screen Replacement: stap 5, afbeelding 2 van 3 Sony Vaio VGN-TXN25N Display Screen Replacement: stap 5, afbeelding 3 van 3
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Sony Vaio VGN-TXN25N Display Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Ricker
71 Reputatie
1 Handleiding geschreven
Cal Poly, Team 5-3, Forte Spring 2012 Lid van Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 3,598
