Ga door naar hoofdinhoud
Sony Vaio VGN-TXN25N Battery Replacement
  1. Sony Vaio VGN-TXN25N Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the computer so that the bottom is facing up.
    • Look to the long edge where the computer screen is hinged and find the "release slide". It is located at the top left corner of the square indent.
  2. Sony Vaio VGN-TXN25N Battery Replacement: stap 2, afbeelding 1 van 1
    • Use your finger to slide the release to the left.
  3. Sony Vaio VGN-TXN25N Battery Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VGN-TXN25N Battery Replacement: stap 3, afbeelding 2 van 2
    • While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide it out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Austen
32 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-3, Forte Spring 2012 Lid van Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 18
Altijd: 1,859
