Ga door naar hoofdinhoud
Sony Vaio VGN-SR140E Screen Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-SR140E Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Screen Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VGN-SR140E Screen Replacement: stap 3, afbeelding 2 van 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Screen Replacement, Screen: stap 4, afbeelding 1 van 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: stap 4, afbeelding 2 van 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: stap 4, afbeelding 3 van 3
    • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
    • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
  5. Sony Vaio VGN-SR140E Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
  6. Sony Vaio VGN-SR140E Screen Replacement: stap 6, afbeelding 1 van 2 Sony Vaio VGN-SR140E Screen Replacement: stap 6, afbeelding 2 van 2
    • Lift screen bezel up and off of the laptop.
  7. Sony Vaio VGN-SR140E Screen Replacement: stap 7, afbeelding 1 van 3 Sony Vaio VGN-SR140E Screen Replacement: stap 7, afbeelding 2 van 3 Sony Vaio VGN-SR140E Screen Replacement: stap 7, afbeelding 3 van 3
    • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
    • Lay the screen gently on the keyboard. This will reveal the screen's connector.
  8. Sony Vaio VGN-SR140E Screen Replacement: stap 8, afbeelding 1 van 3 Sony Vaio VGN-SR140E Screen Replacement: stap 8, afbeelding 2 van 3 Sony Vaio VGN-SR140E Screen Replacement: stap 8, afbeelding 3 van 3
    • Grasp the connector and gently pull it out.
  9. Sony Vaio VGN-SR140E Screen Replacement: stap 9, afbeelding 1 van 1
    • The screen can now be removed.
Conclusie
Jeremy
722 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 1-6, Lauer Spring 2015 Lid van Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 1,127
