Inleiding
The battery needs to removed before servicing or replacing any other component. The RAM is under a panel held on by two screws. The RAM is easy to remove once the panel is off.
Wat je nodig hebt
Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
Bijna klaar!
Conclusie
