Ga door naar hoofdinhoud
Sony Vaio VGN-SR140E Hard Drive Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-SR140E Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Hard Drive Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VGN-SR140E Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Using a Phillips #1 screw driver, loosen both screws holding the cover in place. These screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Lift the cover with a fingernail or plastic opening tool from the side where the screws are present and lift it off to the left.
  6. Sony Vaio VGN-SR140E Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • The hard drive is covered by a thin, black, plastic flap. Gently lift the hard drive up and to the right.
    • Be careful not to damage the ribbon cable during this step.
  7. Sony Vaio VGN-SR140E Hard Drive Replacement: stap 7, afbeelding 1 van 2 Sony Vaio VGN-SR140E Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Use the spudger or a fingernail to carefully release the lock securing the ribbon cable to the motherboard.
  8. Sony Vaio VGN-SR140E Hard Drive Replacement: stap 8, afbeelding 1 van 2 Sony Vaio VGN-SR140E Hard Drive Replacement: stap 8, afbeelding 2 van 2
    • Grasp the ribbon cable carefully near the connector end. Remove it by pulling the cable away from the connector on the motherboard at a slightly upward angle.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jeremy
722 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 1-6, Lauer Spring 2015 Lid van Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 937
