Ga door naar hoofdinhoud
Sony Vaio VGN-SR140E CD/DVD Drive Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VGN-SR140E CD/DVD Drive Replacement: stap 3, afbeelding 2 van 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, CD/DVD Drive: stap 4, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
  5. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: stap 5, afbeelding 1 van 1
    • Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
  6. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
  7. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: stap 7, afbeelding 1 van 1
    • Gently slide the CD/DVD drive out of the laptop.
Conclusie
Jeremy
722 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 1-6, Lauer Spring 2015 Lid van Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 976
