Ga door naar hoofdinhoud
Sony Vaio VGN-S260 Speakers Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-S260 Speakers Replacement, Battery: stap 1, afbeelding 1 van 3 Sony Vaio VGN-S260 Speakers Replacement, Battery: stap 1, afbeelding 2 van 3 Sony Vaio VGN-S260 Speakers Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Speakers Replacement: stap 2, afbeelding 1 van 2 Sony Vaio VGN-S260 Speakers Replacement: stap 2, afbeelding 2 van 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Speakers Replacement, Keyboard: stap 3, afbeelding 1 van 2 Sony Vaio VGN-S260 Speakers Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Speakers Replacement: stap 4, afbeelding 1 van 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Speakers Replacement: stap 5, afbeelding 1 van 2 Sony Vaio VGN-S260 Speakers Replacement: stap 5, afbeelding 2 van 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Speakers Replacement: stap 6, afbeelding 1 van 2 Sony Vaio VGN-S260 Speakers Replacement: stap 6, afbeelding 2 van 2
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Speakers Replacement, Upper Casing: stap 7, afbeelding 1 van 1
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Speakers Replacement: stap 8, afbeelding 1 van 3 Sony Vaio VGN-S260 Speakers Replacement: stap 8, afbeelding 2 van 3 Sony Vaio VGN-S260 Speakers Replacement: stap 8, afbeelding 3 van 3
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Speakers Replacement: stap 9, afbeelding 1 van 1
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Speakers Replacement: stap 10, afbeelding 1 van 3 Sony Vaio VGN-S260 Speakers Replacement: stap 10, afbeelding 2 van 3 Sony Vaio VGN-S260 Speakers Replacement: stap 10, afbeelding 3 van 3
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Speakers Replacement: stap 11, afbeelding 1 van 1
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Speakers Replacement, Speakers: stap 12, afbeelding 1 van 1
    • After removing the Uppercasing, flip it over and locate the two black speakers
  13. Sony Vaio VGN-S260 Speakers Replacement: stap 13, afbeelding 1 van 2 Sony Vaio VGN-S260 Speakers Replacement: stap 13, afbeelding 2 van 2
    • Remove the screws on the speakers
    • Each speaker will have two screws
    • Remove the speakers
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jeffrey Bryan
570 Reputatie
11 handleidingen geschreven
Cal Poly, Team 16-4, Maness Spring 2010 Lid van Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Leden
30 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 5,360
