Ga door naar hoofdinhoud
Sony Vaio VGN-S260 Keyboard Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-S260 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Keyboard Replacement: stap 2, afbeelding 1 van 2 Sony Vaio VGN-S260 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 2 Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Keyboard Replacement: stap 5, afbeelding 1 van 2 Sony Vaio VGN-S260 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Keyboard Replacement: stap 6, afbeelding 1 van 2 Sony Vaio VGN-S260 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Lift up lever underneath the ribbon to detach the keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jeffrey Bryan
570 Reputatie
11 handleidingen geschreven
Cal Poly, Team 16-4, Maness Spring 2010 Lid van Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Leden
30 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 5,476
