Inleiding
The keyboard should be replaced if it is missing keys or non-functional.
Wat je nodig hebt
Power off the laptop.
Unplug the charging cable and any other cables plugged into the laptop.
Turn the laptop over so that the back panel is facing upwards.
Remove all the 8mm Phillips #1 screws on the backside of the laptop.
There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
There are three 3mm screws under the optical drives that also need to be taken out.
Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
Locate and remove three 5.3 mm Phillips #1 screws on the bottom of the fan.
Locate and remove the four 5.3 mm Phillips #1 screws on the top of the fan.
6 andere personen hebben deze handleiding voltooid.
