Ga door naar hoofdinhoud
Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement
  1. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement: stap 2, afbeelding 1 van 1
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Battery Replacement: stap 3, afbeelding 1 van 1
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Conclusie
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
4 andere personen hebben deze handleiding voltooid.
Brian Luu
720 Reputatie
3 handleidingen geschreven
Cal Poly, Team 9-17, Regan Spring 2014 Lid van Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Leden
18 handleidingen geschreven
Één opmerking
How to test my battery performance Sony VAIO
Pcg- 7184L
Ramesh C - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 21
Altijd: 3,262
