Ga door naar hoofdinhoud
Sony Vaio VGN-FS640 RAM Cover Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-FS640 RAM Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 RAM Cover Replacement: stap 2, afbeelding 1 van 1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 RAM Cover Replacement: stap 3, afbeelding 1 van 2 Sony Vaio VGN-FS640 RAM Cover Replacement: stap 3, afbeelding 2 van 2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: stap 4, afbeelding 1 van 2 Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: stap 4, afbeelding 2 van 2
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  5. Sony Vaio VGN-FS640 RAM Cover Replacement: stap 5, afbeelding 1 van 3 Sony Vaio VGN-FS640 RAM Cover Replacement: stap 5, afbeelding 2 van 3 Sony Vaio VGN-FS640 RAM Cover Replacement: stap 5, afbeelding 3 van 3
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
Conclusie
Brian Marchini
293 Reputatie
2 handleidingen geschreven
Cal Poly, Team 24-32, Regan Spring 2010 Lid van Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 11
Altijd: 4,808
