Ga door naar hoofdinhoud
Sony Vaio Tap 11 Wifi Module Replacement
Wat je nodig hebt
  1. Sony Vaio Tap 11 Wifi Module Replacement, Screen Assembly: stap 1, afbeelding 1 van 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Wifi Module Replacement: stap 2, afbeelding 1 van 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Wifi Module Replacement: stap 3, afbeelding 1 van 2 Sony Vaio Tap 11 Wifi Module Replacement: stap 3, afbeelding 2 van 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Wifi Module Replacement, Solid State Disk: stap 4, afbeelding 1 van 1
    • Unplug the battery connector located beside the fan.
    • Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
  5. Sony Vaio Tap 11 Wifi Module Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 3 mm Phillips #000 screws from the right edge of the SSD.
  6. Sony Vaio Tap 11 Wifi Module Replacement: stap 6, afbeelding 1 van 2 Sony Vaio Tap 11 Wifi Module Replacement: stap 6, afbeelding 2 van 2
    • Pull the SSD towards the right and slightly up, removing it from the back assembly.
  7. Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: stap 7, afbeelding 1 van 3 Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: stap 7, afbeelding 2 van 3 Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: stap 7, afbeelding 3 van 3
    • Begin by removing the orange ribbon cable connecting the motherboard to the daughterboard, located above the SSD.
    • Gently tug either side until it releases, then pull out the other end.
  8. Sony Vaio Tap 11 Wifi Module Replacement: stap 8, afbeelding 1 van 1
    • Remove the grey foam separator that was underneath the orange ribbon cable.
  9. Sony Vaio Tap 11 Wifi Module Replacement: stap 9, afbeelding 1 van 1
    • Remove the silver 3 mm Phillips screw that holds the WiFi module in place.
  10. Sony Vaio Tap 11 Wifi Module Replacement: stap 10, afbeelding 1 van 1
    • Remove the black and grey antenna cables from the right side of the device.
  11. Sony Vaio Tap 11 Wifi Module Replacement: stap 11, afbeelding 1 van 1
    • Remove module by gently pulling towards the right.
Conclusie
Alexander Bridges
1.217 Reputatie
7 handleidingen geschreven
IUPUI, Team 1-2, Harley Fall 2015 Lid van IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 2,178
