Ga door naar hoofdinhoud
Sony Vaio Tap 11 Screen Camera Module Replacement Replacement
Wat je nodig hebt
  1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Assembly: stap 1, afbeelding 1 van 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: stap 2, afbeelding 1 van 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: stap 3, afbeelding 1 van 2 Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: stap 3, afbeelding 2 van 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Camera Module Replacement: stap 4, afbeelding 1 van 1
    • Flip device upward carefully like you are turning the page of a book.
  5. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the camera cable from the device backing.
  6. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: stap 6, afbeelding 1 van 1
    • Remove the single 3 mm Phillips #000 screw on the left side of the module.
    • Remove the module from the front panel assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Catanzarite
188 Reputatie
1 Handleiding geschreven
IUPUI, Team 1-2, Harley Fall 2015 Lid van IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Leden
20 handleidingen geschreven
Één opmerking
Is it possible to replace the camera module with a different one? I think that it is a usb camera. I would like to replace it a newer sony model.
Matthew Harper - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 871
