Inleiding
The power plug is one of the most important parts of a laptop or tablet device. Without it, charging the internal battery is impossible!
Wat je nodig hebt
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Disconnect the battery from the motherboard by pulling out the cable below the fan.
Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
I wonder if you have the part number or can supply this power jack?
Yes, Where can I find this replacement part?
